LCOX |
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None ![]() |
This on going problem started after I rebuilt my 1.8 engine last year. Since then I haven't driven the car and I've put it on the back burner and finally ready to face it again.
Rebuilt the 1.8 with all new bearings and new rings. There is a definite engine knock at idle and throughout the rpm range. This is not a ticking noise like a valve out of adjustment but a bottom end knock. I did check valve adjustment and everything I could think of. When I pull the #3 spark plug wire the knock almost completely goes away but not completely but definetly better A couple members said it was probably a rod knock so with the engine in the car I pulled the head and #3 piston and cylinder and tried another rod but the knock is still there. So I guess take the engine apart and look for a mistake I made on the bottom end rebuild right? Anything else I can try? Thanks in advance. L |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
It's a little easier for me because of carbs instead of FI, but:
Disconnect electrical, Position car on stands, remove rear wheels, drain oil = 45 min. Remove shift linkage, throttle & clutch cables, & exhaust (at the stub pipes) = 1 hour disconnect axles @ trans only = 15 min. Drop engine partway = 30 minutes Disconnect trans ground strap that you forgot = 2 minutes Finish engine drop & pull out rear = 5 minutes. Split engine from trans & remove clutch = 15 minutes install yoke & Lift onto engine stand (5 minutes & 1 hour finding someone to help lift it) Disassemble - depends on how cautious you are.... |
Lo-Fi Version | Time is now: 25th June 2024 - 09:58 PM |
