Improved shifting for side shifters, bolt on? Maybe., Experimenting tonight. |
Dr Evil |
Apr 14 2014, 10:14 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have had this though for a long time to try and remove as much slop as I can in the shifting system. The tail shifter is a bit trickier, but not impossible. I have a side shifter in my new 914 and so, while I build up a transmission for it to drive to Hershey this weekend (this will be the raffle transmission, BTW. Trial by fire!), I decided to see how simple it would be to remove some of the slop.
First, see how much of a gap there is between the shift selector comb and the rod. This is a huge amount so any bit that can be removed should be an improvement. Step one was to add material to the sides of the comb faces (Yes, Scotty, I welded). Then, I hand filed the faces and re-formed them to a specific profile. The metal that was added was hardened and a real bitch to file. I figured it was worth it. The end result was a much tighter fit. There are a few parameters that I will not go into that need to be respected to get this to work, but the preliminary results were nice on the bench. With the material added and profiled on the faces, the stick throw fore and aft to select gears decreases significantly. There is still refinement that needs to be done on the profile, but so far the preliminary results are encouraging. Next, I will build a jig so I can directly observe and adjust my profile. And I will also be able to see where I can add material to take up the slack that one feels when they are in gear and can wiggle the stick back and forth. Once I get this prototype done and tested, I can do this treatment to any side shift console on an exchange basis and it will be a quick bolt on improvement (I hope). (IMG:style_emoticons/default/happy11.gif) |
Dr Evil |
May 30 2014, 09:23 AM
Sorry, Dave. I have been super busy. I did figure out that one problem I was having has an easy solution that actually further improves things. I had been having trouble getting into 1st while stopped. Embarrassing and will need to replace the 1st parts before this ships to its new owner (IMG:style_emoticons/default/wink.gif) Well, the problem is that I can move the stick far left and right, like normal, but with my enhancements this much motion is not necessary. Simple, I will put it into 1st, measure the gap between the the shift ball month and the housing, and install a washer/shim of the right thickness. Now pattern is smaller. Probably can do this for 4-5, too, but they did not have a problem as when car is moving the shifter is guided into position easier.
Also, I have finally received my short shift kit. Took a month after ordering from pelican....sheesh. I look forward to evaluating this. Another upgrade I am working on requires me to get another internal tunnel shift rod to be sacrificed (IMG:style_emoticons/default/happy11.gif) Have not had time to search. I am considering ways I can just make these and ship them, but they are so precise that any rotation on your internal shift rods, which would normally be well tolerated, would lead to binding and aggravation. If people are not interested in pulling their stack to adjust, or have me adjust, I could easily write instructions on how to remove material from the comb depending on what issue you are having. This will be available! I am just interested in getting it as awesome as I can before I get them out to the people. Probably another 6mo out. Lots going on here at home (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 28th December 2024 - 01:50 AM |
