Basic parts list |
Basic parts list |
partwerks |
May 12 2014, 08:12 PM
Senior Member Group: Members Posts: 1,599 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
In terms of cost, here’s a basic parts list from Renegade:
$8500 LS3 engine package 430hp (480hp $500 more) $2600 914 LS basic kit $2200 914 LS Boxster LS clutch and adapter upgrade $250 Starter $1200 Heavy Duty Axles $595 Rear Trans mount $750 Misc. Hydraulic Clutch Conversion Parts $375 Boxster S shifter and cables $3000 Good used Boxster S transaxle $175 Air Cleaner Kit $180 Sport mount kit for trans $120 Poly mounts for engine $750 GPS speedometer upgrade (do I really need this??) |
Mike Bellis |
May 31 2014, 05:45 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Better gear ratios for V8 engines come from Audi TDI trannies like this one. The TDI's are torqey motors with a higher final drive than the Boxster 6 speed. This makes them ideal for a V8 conversion.
http://www.ebay.co.uk/itm/AUDI-A6-C5-2-5-V...=item1c40be5d80 This is a 6 speed. from the looks it is a 012 front with a 01E rear section. But Audi & Getrag made trannies with interchangeable parts. The 012 is the same casting as the Boxster 5 & 6 speed. Some Boxster trannies have a different bell housing than this. Now you would have to fab shift linkage for this one but it's easy to copy the Boxster setup. I did this on my 5 speed since it originally came from a Passat not a Boxster and one of the bosses was not drilled and tapped like the Boxster. In this case, you could swap this into a Boxster or my car and it would bolt right on. ebay UK is a great resource to find FWD TDI trannies. As I said before, TNT Shipping air freighted my 6 speed from UK to San Francisco in 4 days for $245. You would only need the seller to strap it to a pallet. |
Lo-Fi Version | Time is now: 6th January 2025 - 08:40 PM |
