idle on a 2056 with 9590 cam |
jmargush |
Dec 12 2013, 03:50 PM
Member Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am having trouble getting my new 2056 with a 9590 cam to idle. When I start it is idles around 500rpm or lower and I can't speed it up with the by pass screw.
I am running L-jet injection I hear a hissing sound when the engine is idling but I cannot find a vacuum leak, plenum couplers are new and all other hoses are in good shape. I can't find the hissing with a mechanics stethoscope so I was going to try to find a leak with propane but it has been too cold to work on it lately. The idle does seem to get a little better after it has warmed up a bit I think, it has been several weeks since I have had it out. One question I had is does the new cam require any change to the mixture? if so how do I go about adjusting the mixture? Thanks in advance for any input |
crash914 |
Jun 2 2014, 10:53 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
hmmm.. this would explain why I have to use the throttle stop to get the idle I want...the bypass screws don't do much if anything.
I don't pull a very large vacuum at idle..but can get a pretty decent 800 rpm.. |
Jake Raby |
Jun 2 2014, 12:01 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
hmmm.. this would explain why I have to use the throttle stop to get the idle I want...the bypass screws don't do much if anything. Exactly. QUOTE I don't pull a very large vacuum at idle..but can get a pretty decent 800 rpm.. You can't have vacuum without chamber filling. You can't have chamber filling without intake volume. |
Lo-Fi Version | Time is now: 26th June 2024 - 11:05 AM |
