jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I am having trouble getting my new 2056 with a 9590 cam to idle. When I start it is idles around 500rpm or lower and I can't speed it up with the by pass screw.
I am running L-jet injection I hear a hissing sound when the engine is idling but I cannot find a vacuum leak, plenum couplers are new and all other hoses are in good shape. I can't find the hissing with a mechanics stethoscope so I was going to try to find a leak with propane but it has been too cold to work on it lately. The idle does seem to get a little better after it has warmed up a bit I think, it has been several weeks since I have had it out. One question I had is does the new cam require any change to the mixture? if so how do I go about adjusting the mixture? Thanks in advance for any input |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
QUOTE Its doubtful that drilling a hole in the throttle plate will improve the function of your system. I disagree. QUOTE The idle is so low because there isn't enough fuel for the amount of air getting in the engine. I disagree. The idle is low because the engine that is now breathing more effectively at idle speed now has a much greater demand for chamber filling. Because of this the air bypass screw becomes extended so far that idle air often fluctuates. Drilling the throttle plate allows bypass air to occur, thus reducing the amount of air that must pass through the factory idle air bypass circuit. Drilling the throttle plate with this combination is often required, especially at lower elevations, as air density effects the bypass volumes even more. The other thing that can impact this is initial timing advance, the key to tuning this combination is optimizing initial advance, advance curve and idle air bypass quantity. After these are complete, one can move to enrichment. Thats my input as the designer of the camshaft profile, and they guy that has not only made it work a couple thousand times; but also made it work the first time. |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
I have a 9550 cam, with Ljet. Whereabouts might this hole get drilled? I'm chasing my last (hopefully) vacuum leak this evening, and depending on how that affects things, I may need to try the drill my idle still hunts at temp. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:58 AM |
