Transaxle stack replacement?, Or do I need to change the entire transaxle? |
scott_in_nh |
Jun 4 2014, 07:52 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I bought a used transaxle that I am hoping shifts better than the one I have.
If it doesn't then at least I have a core to rebuild while the car is still on the road. Can I just lower the rear of the trans a bit and swap out the gear stack or am I looking at taking the entire transaxle out? Thanks, Scott |
toolguy |
Jun 4 2014, 08:42 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Can and should are two different things. .
the ring and pinion gears are a mated set. . At the least, you'd need to re-set the pinion depth [gaskets are shims] and that requires mandrels and dial indicators. . |
Lo-Fi Version | Time is now: 26th June 2024 - 09:51 AM |
