jsaum |
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None ![]() |
I got an awesome deal on a 1.8 motor and am ready to put the flywheel on I want to make sure I'm setting the end play correctly the Haynes manual says to use two shims measure the play, max travel and then subtract .004 and that will give you the correct shim to use for the third one correct? I'm using a dial indicator gauge and it seems pretty straight forward is there anything to watch out for?
Thanks, Jsaum |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
That'll do. Be sure to check it after you've installed the shim pack, and before you install the seal and o-ring.
The Cap'n |
Lo-Fi Version | Time is now: 29th June 2024 - 04:19 AM |
