Rleog |
Senior Member ![]() ![]() ![]() Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States ![]() ![]() |
I'm adding relays to my headlight circuits.
The 5 terminals and their functions: 30 = current input 86 = trigger current input 85 = ground 87 = current output 87b = current output ? My question: when the relay is triggered, are both 87 and 87b active, or is this an either/or arrangement? I'm hoping to wire one headlight to 87 and the other to 87b. Thanks |
Dtjaden |
Member ![]() ![]() Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California ![]() |
Current will flow from pin 30 to pin 87a when the relay is inactive (when there is no current flowing between pins 85 & 86). Current will flow from pin 30 to pin 87 when the relay is active.
So the answer to wether you can connect one headlight to pin 87 and one to pin 87a is no. These relays are rated at 30 amps so there should be no problem hooking both headlights to one relay, both to pin 87. 30 amps at 12v = 360 watts, far more than the two headlights would draw. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:17 AM |
