jsaum |
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None ![]() |
I got an awesome deal on a 1.8 motor and am ready to put the flywheel on I want to make sure I'm setting the end play correctly the Haynes manual says to use two shims measure the play, max travel and then subtract .004 and that will give you the correct shim to use for the third one correct? I'm using a dial indicator gauge and it seems pretty straight forward is there anything to watch out for?
Thanks, Jsaum |
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
How much 'force' do you use to check end play? I've seen it done by hand and with a screwdriver prying a little at either end.
I've always used hand pressure. Thoughts? |
Lo-Fi Version | Time is now: 29th June 2024 - 04:56 AM |
