jsaum |
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None ![]() |
I got an awesome deal on a 1.8 motor and am ready to put the flywheel on I want to make sure I'm setting the end play correctly the Haynes manual says to use two shims measure the play, max travel and then subtract .004 and that will give you the correct shim to use for the third one correct? I'm using a dial indicator gauge and it seems pretty straight forward is there anything to watch out for?
Thanks, Jsaum |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
How much force can your hand generate ??? I've always used a rubber mallet / hammer to tap the crank both ways to get as much freeplay out to determine shim stack . While I'm not talking hammering the snot out of the crank , just a firm whack to seat it both ways to get as accurate a reading as possible , both feeler gauge and dial indicator .
YMMV..... Jack |
Lo-Fi Version | Time is now: 29th June 2024 - 04:38 AM |
