mojorisen914 |
Visit your local strip club ![]() ![]() ![]() Group: Members Posts: 695 Joined: 9-July 06 From: Denver Colorado Member No.: 6,403 Region Association: Rocky Mountains ![]() |
I know I have read somewhere about the correct wiper column switch that will work for a teener on here or other forums but can't remember for the life of me where I read it. I want to upgrade to a column switch that will work in conjunction with an electric washer pump. I thought a switch from a 924 would work but then maybe it's a 944. Hell if I can remember....
Can anyone give me a part number and where to purchase one? Like everyone else; I'm looking for a place that has a good deal. Thanks. |
zambezi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States ![]() |
I was under the impression that the true 924 switch would have an electrical switch located where our pressure valve is located. If not I don't see the need to "update" to a 924 part when it is the same as what we already have.
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
I was under the impression that the true 924 switch would have an electrical switch located where our pressure valve is located. If not I don't see the need to "update" to a 924 part when it is the same as what we already have. I use this one. The extra wire, outside the connector, is for the electric pump. All the wire in the connector are in the right place. It's on top of the pneumatic option that I don't use any more and can be taken off. Basically, it's just plug an play with the addition of the electric pump. http://www2.cip1.com/ProductDetails.asp?Pr...2D953%2D519%2DG |
zambezi |
I was under the impression that the true 924 switch would have an electrical switch located where our pressure valve is located. If not I don't see the need to "update" to a 924 part when it is the same as what we already have. I use this one. The extra wire, outside the connector, is for the electric pump. All the wire in the connector are in the right place. It's on top of the pneumatic option that I don't use any more and can be taken off. Basically, it's just plug an play with the addition of the electric pump. http://www2.cip1.com/ProductDetails.asp?Pr...2D953%2D519%2DG So it actually has both, a momentary switch and a pressure valve? That would work then. Just disregard the valve portion and wire in an electric pump. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:13 AM |
