recent Sebring Abuse, Oil system help |
Jetsetsurfshop |
Dec 17 2013, 10:32 AM
Senior Member Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
Jetsetsurfshop |
Jun 15 2014, 11:18 AM
Took the screen off and added brackets to hold the bumper in place.
Attached thumbnail(s) |
Seabird |
Jun 15 2014, 05:30 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Took the screen off and added brackets to hold the bumper in place. I was at it with my cooler today too. Added a ducting from the fan in the front valance back to the cooler and added to Chris's shroud to scoop more air from the under car stream. I ended up removing the flap on the passenger side like you did. Can't wait till next weekend! I am going to pit with the Condor crew by turn 17, do you mind moving down that way? Going to try to get there early. Miguel |
Jetsetsurfshop |
Jun 15 2014, 05:56 PM
Took the screen off and added brackets to hold the bumper in place. I was at it with my cooler today too. Added a ducting from the fan in the front valance back to the cooler and added to Chris's shroud to scoop more air from the under car stream. I ended up removing the flap on the passenger side like you did. Can't wait till next weekend! I am going to pit with the Condor crew by turn 17, do you mind moving down that way? Going to try to get there early. Miguel Hey Miguel, If my cooler doesn't work to my liking this weekend then front cooler it is. Did you figure out your pressure drop? I wonder if you had enough oil in your car. When I first installed my accusump I had problems with "knowing" my oil level. Looking forward to seeing your new duct work. (IMG:style_emoticons/default/biggrin.gif) I'll be pitting with my corvette buddy. I'm bringing my bike, I'll be down there all day! Shane |
Lo-Fi Version | Time is now: 9th January 2025 - 02:17 PM |
