Jetsetsurfshop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States ![]() |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
Jetsetsurfshop |
Brant,
Would you change anything on your oil cooler set up you have now? Crossflow cooler? Hood exit? After this weekend at Sebring I'm going to start engineering front cooling. Shane |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Brant, Would you change anything on your oil cooler set up you have now? Crossflow cooler? Hood exit? After this weekend at Sebring I'm going to start engineering front cooling. Shane I do think that frontal air with an unrestricted and even assisted exit is the best. So. Hood exit is the best I have one 914 with a hood exit and it cooled well even with a modified 4 AN-12 by the way. I won't change my orange car as a hood exit is not allowed in vintage |
Lo-Fi Version | Time is now: 26th June 2024 - 08:29 PM |
