hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
Lately when driving the car seems as if my feet are hitting each other when on the clutch and brake at the same time... funny my feet are not that big lol. I've attached a pic of what i found this morning when i went looking at the pedal assy. so my question is .... if i clip the bailing wire that the po put on there can i just slip the pedal off and clean it up find the right size roll pin and put it all back together or will i need to pull the whole assy? Was planning on re building it this coming winter, just want to drive the pumpkin now that it is nice out side.
thanks ![]() |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Sorry my error, it looks correct in the picture. . .
With the clevis connected, go back to the trans, connect everything around the roller pulley, and start tightening the 11mm nuts until the pedal is pulled up to within 1/2 inch of it highest possible place. . That 1/2" clearance allows to throwout bearing to 'gently' ride on the pressure plate. . . add the other 11mm "pal" lock nut. . you should feel an almost immediate resistance of the pressure plate springs when pressing the pedal. . not mussy, it's a solid resistance of the pressure plate fingers being depressed. . |
Lo-Fi Version | Time is now: 25th June 2024 - 01:21 AM |
