914bub |
Member ![]() ![]() Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None ![]() |
So I've searched and searched online and I can't find an engine vacuum hose diagram for my 72 914, (1.7). If anybody can help me out I would greatly appreciate it.
I am also looking for a torque spec for the nuts that attach the heat exchangers to the heads. Thanks in advance! Bub |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Those 2 hoses are of different diameters, IIRC, so there shouldn't be any confusion. Did the '72s even have a decel valve? If so, where was the tap for the small hose? The '72 was a one year only version and had a temperature controlled vacuum switch in the air cleaner for the heat riser. That tap was in the rubber hose between the AAR and the intake plenum.
The Cap'n |
Lo-Fi Version | Time is now: 25th June 2024 - 06:46 PM |
