jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
2056 running L jet
Drive the car for about 30 min parked it for about 15 then started back. It started to cut out and then just died. It will start and run for a few seconds but then dies. There is fuel and spark. Any ideas? Don't see any pinched lines any where. Ambient temp is 77 degrees |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
Cutting out sounds like fuel starvation. Your sock idea is logical, mimics the effect of a clogged fuel filter. Pull your new filter (easier than the tank (IMG:style_emoticons/default/chair.gif)) and check for ANY signs of contamination which may indicate crud. IIRC, you can get a flashlight and see the sock either thru the sender hole or filler once removed.
Lo-Fi Version | Time is now: 25th June 2024 - 01:15 AM |
