jacksun |
Member ![]() ![]() Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest ![]() |
hi,
my question is regarding the oil filter flange and where I might purchase the gasket between the flange and the case? also. the oil pump in the image was covered in oil... does this mean that the pump seals need replaced? or is it oil coming from the oil cooler gasket or also from the push rod seals or the valve cover gasket... or all three.. there was no oil on the top of the engine bar between the motor mounts. any thoughts are appreciated. thanks randal ![]() ![]() |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
....Alot of the Permatex products,are better than a "gasket"(paper)!!!
(IMG:style_emoticons/default/bye1.gif)(But if you must have 1.....Try local VW shop or P-car dealer!) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:06 PM |
