jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
2056 running L jet
Drive the car for about 30 min parked it for about 15 then started back. It started to cut out and then just died. It will start and run for a few seconds but then dies. There is fuel and spark. Any ideas? Don't see any pinched lines any where. Ambient temp is 77 degrees |
jmargush |
Just tried to start it and it is still doing the same thing.
put a meter on the pump contacts and no voltage when I move the flapper in the airbox (key on). There is voltage when the engine is cranking but as soon as it starts and I let off the starter no voltage. Does this point to the relay? Refresh my memory is the pump relay on the relay board in the engine compartment? Or should I check something else? |
motorvated |
Member ![]() ![]() Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
Just tried to start it and it is still doing the same thing. put a meter on the pump contacts and no voltage when I move the flapper in the airbox (key on). There is voltage when the engine is cranking but as soon as it starts and I let off the starter no voltage. Does this point to the relay? Refresh my memory is the pump relay on the relay board in the engine compartment? Or should I check something else? Fuel pump relay is hanging off the battery tray. I'd check for loose or unconnected wires there for sure. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:46 AM |
