jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Put my engine back together in November, and have been driving since then. Couple of 200 miles drives, mostly around town. Itts a 2056, webers, cam, nothing super high power. This weekend it started an awful clunk deep inside, and I got it off the road and towed home.
Got her puller apart, and here is what I have found. Crank broke threw the rearmost counterweight. How does this happen? So I need a new crank. What else should I replace? Obviously all main bearings. Rod bearings too? Attached thumbnail(s) ![]() Attached image(s) ![]() |
Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
I'd inspect the case before trashing it. I've seen a decent number of cranks break in different motors and not hurt anything (other than the crank).
Expensive and not fun way to make paper weights. It sucks when you have to add a second broken parts shelf to the garage..... |
jeffdon |
I'd inspect the case before trashing it. I've seen a decent number of cranks break in different motors and not hurt anything (other than the crank). Expensive and not fun way to make paper weights. It sucks when you have to add a second broken parts shelf to the garage..... Looks like it hit the case. Marks that look like rough machine marks, but not even like machining. Deeper at the top. Is my case toast? Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:52 PM |
