Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
Hi all,
Before I go down what seems like the obvious but wrong path. Just got a new tips sensor board from 914rubber.com. When installing, shouldn't remove the tps assembly from the engine or leave it in place. I was thinking it may need to come off but don't know if that opens a can of works in terms of linkage,gaskets, etc. Thanks, Mike |
Amphicar770 |
Thanks. Changed it this evening, have not had a chance to test drive. Could definitely see the wear on the old one even with only 45k miles on the odometer.
One bit of oddness I experienced on my '74 2.0 I replaced the throttle position circuit board. Put the TB back on car, hooked up some jumpers and could not get a reading other than 1. Figuring I might have the jumpers wrong I again removed the TB. Jumpers were correct and I was able to calibrate on the bench. Left the jumpers in place, put the TB back on car. Checked reading, still zero. I now hook the linkage back up and notice the reading is back at 1. Loosen the screws, go to adjust and same as before, only shows 1 no matter how I turn the assembly. Seems to be OK with bench calibration but not sure why I can't seem to calibrate on the car? |
swooshdave |
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest ![]() |
Amphicar770 |
Seems to be OK with bench calibration but not sure why I can't seem to calibrate on the car? What did you do to get it working? I just went with the bench calibration and it seems just fine. I did read somewhere else that you have to make sure the tps butterfly is closed completely which it is in the bench but may not be after cables are hooked up. I considered checking again but for now if it ain't broke, don't fix it. |
Lo-Fi Version | Time is now: 1st July 2024 - 06:15 AM |
