chris914 |
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California ![]() |
When I turn the ignition on the pump doesn't run. It's a stock 74 2.0L.
Are the two wires connected to the pump +/- 12 volts? I used a multimeter and there doesn't seem to be any voltage going to the pump. Is there a relay that supplies voltage or does it come from the ignition switch. I did check the fuses and made sure they were seated. Thanks! |
MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
What a great response from Clay Perrine....
Lo-Fi Version | Time is now: 24th June 2024 - 11:22 PM |
