EFI Fuel Pump Question, Fuel pump doesn't run |
chris914 |
Jul 1 2014, 10:34 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
When I turn the ignition on the pump doesn't run. It's a stock 74 2.0L.
Are the two wires connected to the pump +/- 12 volts? I used a multimeter and there doesn't seem to be any voltage going to the pump. Is there a relay that supplies voltage or does it come from the ignition switch. I did check the fuses and made sure they were seated. Thanks! |
Mike Bellis |
Jul 1 2014, 10:37 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The stock 914 FI does not have a priming cycle like modern EFI. The trigger points in the dizzy tell the ECU to turn on the pump and fire injectors.
Cap'n Krusty |
Jul 2 2014, 08:47 AM
Lo-Fi Version | Time is now: 24th June 2024 - 11:59 PM |
