crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
ok, I need help. currently I am about 3 to 5 seconds off the pace in my local club events. I know most of the time is due to the driver. I think that there is some time in the car also as it is mostly set up for the long track.
Here is what I know so far, if more info is needed..ask... 73 914, blue. bolt in cage, just the 4 plates plus the seat belt for tie in points. stiffly sprung, Koni yellows, I think 250 lbs in the rear and 21 or 23mm torsion bars in the front. Delrin bushings everywhere, I have needle bearings, just not installed. lowered, see pictures for height. 4 inches in the rear to the bottom of the engine mount bar, 4 inches in front to the bottom of the front floor pan. 205 50 15 tires, not sure of the wheel width, 4 lug. my tires are about 8 year old khumo v710's that have been in the garage and have 4 autocross days on them now. air pressure I have been running, 22lbs front, 20 rear. see pictures for chalk. looks like I am using all the tread. Camber is close to -2.4 degrees front and rear. Front toe is 0, not sure about the rear, perhaps 1/4 inch toe in. Motor is 103 by 80, nickies, split cam, le200 heads, tangerine header, 6800 rpm redline, 11:1 compression, so plenty of grunt. Megasquirt with twin throttle bodies. Transmission is open diff, with a flipped 5th gear for 3rd and standard 5th. no camber plates, See pictures in the following posts.. |
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Everyone touched on some really great points. I don't have much to add except try to keep it in close to the key cones such as sweepers and slaloms. Here is a couple of vids from earlier in the month. I had a bunch of trouble going into the sweeper because I couldn't heel toe with my new shoes and it cost me a bunch of time.
https://www.youtube.com/watch?v=TE4QWNzKhys...Wm8bK1V5SXqdhrQ Keeping it in close. https://www.youtube.com/watch?v=o5LXqWb2YAY...Wm8bK1V5SXqdhrQ |
crash914 |
NICE! I like the low camera angle..
Everyone touched on some really great points. I don't have much to add except try to keep it in close to the key cones such as sweepers and slaloms. Here is a couple of vids from earlier in the month. I had a bunch of trouble going into the sweeper because I couldn't heel toe with my new shoes and it cost me a bunch of time. https://www.youtube.com/watch?v=TE4QWNzKhys...Wm8bK1V5SXqdhrQ Keeping it in close. https://www.youtube.com/watch?v=o5LXqWb2YAY...Wm8bK1V5SXqdhrQ |
Lo-Fi Version | Time is now: 26th June 2024 - 08:32 AM |
