PlantMan |
Member ![]() ![]() Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California ![]() |
Hey All,
I saved this car, I am sure, from pending doom as it was sitting in a Coparts yard in the SF Bay area, not to mention it was donated to charity........ I thought it had potential so I scooped it up. My last 914 was a 1.7 (72) and I always wanted the 73-74 2.0l, so here we are. Anyways, you can see from the attached photos she is a little long in the tooth!!! BTW, this car is a true California car and appears to have spent it's entire life in NorCal. Who said Cal cars have little rust??? It also appeared to have a trans change-out around 30k miles, interesting. I have gone through 80% so far, got the car up and running, fixed a majority of the oil leaks, and now getting the brakes sorted out so I can road test it. Interior is in very good shape, minus the carpet, dashboard is a solid A grade for 40 years old and the seats and back pad are still quality as well. I am debating the AC system, which I will remove for now, but it might go back in in the future. The motor starts right-up without any problems and after I get the brakes back on I am going to check for vacuum leaks, it has a high idle but I think maybe the AAR maybe stuck. Debating the next step, starting from the front of the car and possibly working my way to the back, doing the body work. I am trying to gather pieces now for the sheet metal clean-up. Enjoy the photos! I did add it to the VIN database as well. ![]() ![]() ![]() ![]() ![]() 680] ![]() ![]() ![]() ![]() ![]() ![]() 688] Attached image(s) ![]() ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Yep. that's a parts car. Not worth the amount of metal word required. (IMG:style_emoticons/default/sad.gif)
But I see lots of good parts. |
Lo-Fi Version | Time is now: 27th June 2024 - 03:31 AM |
