Help me win at autocross, I wanna be a top 10 car and driver! |
crash914 |
Jul 1 2014, 06:49 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
ok, I need help. currently I am about 3 to 5 seconds off the pace in my local club events. I know most of the time is due to the driver. I think that there is some time in the car also as it is mostly set up for the long track.
Here is what I know so far, if more info is needed..ask... 73 914, blue. bolt in cage, just the 4 plates plus the seat belt for tie in points. stiffly sprung, Koni yellows, I think 250 lbs in the rear and 21 or 23mm torsion bars in the front. Delrin bushings everywhere, I have needle bearings, just not installed. lowered, see pictures for height. 4 inches in the rear to the bottom of the engine mount bar, 4 inches in front to the bottom of the front floor pan. 205 50 15 tires, not sure of the wheel width, 4 lug. my tires are about 8 year old khumo v710's that have been in the garage and have 4 autocross days on them now. air pressure I have been running, 22lbs front, 20 rear. see pictures for chalk. looks like I am using all the tread. Camber is close to -2.4 degrees front and rear. Front toe is 0, not sure about the rear, perhaps 1/4 inch toe in. Motor is 103 by 80, nickies, split cam, le200 heads, tangerine header, 6800 rpm redline, 11:1 compression, so plenty of grunt. Megasquirt with twin throttle bodies. Transmission is open diff, with a flipped 5th gear for 3rd and standard 5th. no camber plates, See pictures in the following posts.. |
infraredcalvin |
Jul 5 2014, 10:06 PM
Distracted Member Group: Members Posts: 1,533 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Don't make any changes to the car.
Have one of the fast drivers drive your car , I'll bet they'll make it within a 1-2 sec of your target time with no changes except the driver. If you can ride with them in one of those runs, even better. Watch their lines/technique, etc. all great comments above, but learn how to drive first, constantly tweaking your car while you are trying to learn is just going to extend your learning curve. Take notes, videos, review them. Once you get close to those times, then start making tweaks 1 at a time - make a small tweak, see what to does, another, then test... You'll get an idea of what changes have the maximum effect for your driving style. Good luck have fun! |
Lo-Fi Version | Time is now: 26th June 2024 - 08:40 AM |
