crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
ok, I need help. currently I am about 3 to 5 seconds off the pace in my local club events. I know most of the time is due to the driver. I think that there is some time in the car also as it is mostly set up for the long track.
Here is what I know so far, if more info is needed..ask... 73 914, blue. bolt in cage, just the 4 plates plus the seat belt for tie in points. stiffly sprung, Koni yellows, I think 250 lbs in the rear and 21 or 23mm torsion bars in the front. Delrin bushings everywhere, I have needle bearings, just not installed. lowered, see pictures for height. 4 inches in the rear to the bottom of the engine mount bar, 4 inches in front to the bottom of the front floor pan. 205 50 15 tires, not sure of the wheel width, 4 lug. my tires are about 8 year old khumo v710's that have been in the garage and have 4 autocross days on them now. air pressure I have been running, 22lbs front, 20 rear. see pictures for chalk. looks like I am using all the tread. Camber is close to -2.4 degrees front and rear. Front toe is 0, not sure about the rear, perhaps 1/4 inch toe in. Motor is 103 by 80, nickies, split cam, le200 heads, tangerine header, 6800 rpm redline, 11:1 compression, so plenty of grunt. Megasquirt with twin throttle bodies. Transmission is open diff, with a flipped 5th gear for 3rd and standard 5th. no camber plates, See pictures in the following posts.. |
crash914 |
got it! oh and have fun!
Has anyone ever seen a throttle/brake light indicator for Ax? I will try to hook up something to my megasquirt for the throttle, I guess somewhere above 80% and to my brake light switch....that way I can see when I am on the gas/brake....It would be nice to find something already in production.... |
koozy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None ![]() |
got it! oh and have fun! Has anyone ever seen a throttle/brake light indicator for Ax? I will try to hook up something to my megasquirt for the throttle, I guess somewhere above 80% and to my brake light switch....that way I can see when I am on the gas/brake....It would be nice to find something already in production.... Your money is better spent on tires. You can hook a light up to the brake switch and set it so you see it on the video. That will help but only if you remember to apply it on the course next time you drive. Everyone learns a little differently. You may benefit tremendously from that. Though, once you get the hang of it you will know by looking and listening when watching the video, little red light or not. Look at them enough and you will know. Just set the basics on the car and drive. There ain't no smoking gun here. Drive the piss outa that car. Judging by that video, you ain't doing that yet. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:20 PM |
