PlantMan |
Member ![]() ![]() Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California ![]() |
Hey All,
I saved this car, I am sure, from pending doom as it was sitting in a Coparts yard in the SF Bay area, not to mention it was donated to charity........ I thought it had potential so I scooped it up. My last 914 was a 1.7 (72) and I always wanted the 73-74 2.0l, so here we are. Anyways, you can see from the attached photos she is a little long in the tooth!!! BTW, this car is a true California car and appears to have spent it's entire life in NorCal. Who said Cal cars have little rust??? It also appeared to have a trans change-out around 30k miles, interesting. I have gone through 80% so far, got the car up and running, fixed a majority of the oil leaks, and now getting the brakes sorted out so I can road test it. Interior is in very good shape, minus the carpet, dashboard is a solid A grade for 40 years old and the seats and back pad are still quality as well. I am debating the AC system, which I will remove for now, but it might go back in in the future. The motor starts right-up without any problems and after I get the brakes back on I am going to check for vacuum leaks, it has a high idle but I think maybe the AAR maybe stuck. Debating the next step, starting from the front of the car and possibly working my way to the back, doing the body work. I am trying to gather pieces now for the sheet metal clean-up. Enjoy the photos! I did add it to the VIN database as well. ![]() ![]() ![]() ![]() ![]() 680] ![]() ![]() ![]() ![]() ![]() ![]() 688] Attached image(s) ![]() ![]() |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
And I agree you should move the ECU back...just not a great place for it. The stress on the wires is also not good. It goes here....looks like there's room. As Rick said get the bracket or make one.
blabla914 |
I like primer ![]() ![]() Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None ![]() ![]() |
And I agree you should move the ECU back...just not a great place for it. The stress on the wires is also not good. It goes here....looks like there's room. As Rick said get the bracket or make one. ![]() I had an AC equipped car a while back. If I remember correctly I tried to mount the ECU with the correct bracket and it interfered with the AC compressor. Maybe I did it wrong, but I'm 90% certain it's not going to work. Mine was attached further up on the firewall with two little L brackets. |
Lo-Fi Version | Time is now: 29th June 2024 - 05:15 PM |
