crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
ok, I need help. currently I am about 3 to 5 seconds off the pace in my local club events. I know most of the time is due to the driver. I think that there is some time in the car also as it is mostly set up for the long track.
Here is what I know so far, if more info is needed..ask... 73 914, blue. bolt in cage, just the 4 plates plus the seat belt for tie in points. stiffly sprung, Koni yellows, I think 250 lbs in the rear and 21 or 23mm torsion bars in the front. Delrin bushings everywhere, I have needle bearings, just not installed. lowered, see pictures for height. 4 inches in the rear to the bottom of the engine mount bar, 4 inches in front to the bottom of the front floor pan. 205 50 15 tires, not sure of the wheel width, 4 lug. my tires are about 8 year old khumo v710's that have been in the garage and have 4 autocross days on them now. air pressure I have been running, 22lbs front, 20 rear. see pictures for chalk. looks like I am using all the tread. Camber is close to -2.4 degrees front and rear. Front toe is 0, not sure about the rear, perhaps 1/4 inch toe in. Motor is 103 by 80, nickies, split cam, le200 heads, tangerine header, 6800 rpm redline, 11:1 compression, so plenty of grunt. Megasquirt with twin throttle bodies. Transmission is open diff, with a flipped 5th gear for 3rd and standard 5th. no camber plates, See pictures in the following posts.. |
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
As a Potomac member I will chime in with some other things..
1) The lot is hard. Low grip. imho, if you are not on the knife edge of slip angles, you will not carry any speed. 2) For me, AX is an on/off switch.. don't feather shit.. just bam on and bam off.. gas, brakes etc. 3) I found running same pressurs front/rear was the best place to start. imho, 20 is too low. I always preferred 26-28 all around.. sometimes even 30 all around. 4) would love to take a ride and help out if I can get to an event this year. The new cars have tremendous advantages. Bill C or Vrankovich in their Caymans are very good drivers in a nicely set up car. 275+ width R comps or Hoosiers will make anyone fast. As mentioned, new soft 205-50 rubber would drop 2 seconds for you. The new cars also have a rev advantage (say 68-7500rpm.. means less gears needed.. less errors in shifting too.. Seat time is the best advice... get more and more.. Run Chesapeake and Potomac events.. maybe SCCA (badly classified) and Capital Driving Club too. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:42 PM |
