Master Cylinder install tips? |
914bub |
Jul 21 2014, 07:12 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Hey guys. I can't get the metal lines that go into the grommets on top of my new master cylinder to quit leaking. Initially I installed the master cylinder and then the the lines to the reservoir last. Next I loosened the bolts that mount the master to the car (with all the threaded metal lines still attached) and I felt like I got the lines pulled a lot more securely in the grommets. Didn't leak for days before I bled it and then a few days after bleeding it it started leaking again. I'm pulling my hair out. Any "tips"?
914bub |
Jul 24 2014, 08:03 PM
Hey guys,
Thanks for the replies. The master did have new grommets but they seemed shallower than the originals so I actually got it to stop leaking by installing one of the taller original grommets in the forward most circuit. The reason I said I loosened the master cylinder is because with it bolted in, trying to pull the lines deeper into the grommets the rear one hits the body. Once I loosened it and pulled the rear down a little further when I bolted the master back in the rear line cleared the body fine. I'm ready to install hose clamps and call it done but I know that isn't the right way to go. Does anybody sell new grommets that are not after market? Thanks,Bub |
Lo-Fi Version | Time is now: 26th June 2024 - 07:10 AM |
