crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
ok, I need help. currently I am about 3 to 5 seconds off the pace in my local club events. I know most of the time is due to the driver. I think that there is some time in the car also as it is mostly set up for the long track.
Here is what I know so far, if more info is needed..ask... 73 914, blue. bolt in cage, just the 4 plates plus the seat belt for tie in points. stiffly sprung, Koni yellows, I think 250 lbs in the rear and 21 or 23mm torsion bars in the front. Delrin bushings everywhere, I have needle bearings, just not installed. lowered, see pictures for height. 4 inches in the rear to the bottom of the engine mount bar, 4 inches in front to the bottom of the front floor pan. 205 50 15 tires, not sure of the wheel width, 4 lug. my tires are about 8 year old khumo v710's that have been in the garage and have 4 autocross days on them now. air pressure I have been running, 22lbs front, 20 rear. see pictures for chalk. looks like I am using all the tread. Camber is close to -2.4 degrees front and rear. Front toe is 0, not sure about the rear, perhaps 1/4 inch toe in. Motor is 103 by 80, nickies, split cam, le200 heads, tangerine header, 6800 rpm redline, 11:1 compression, so plenty of grunt. Megasquirt with twin throttle bodies. Transmission is open diff, with a flipped 5th gear for 3rd and standard 5th. no camber plates, See pictures in the following posts.. |
crash914 |
Ok, here is a video of my fastet run. I just need to go faster! The data logs of my runs show that I was only about .8g's in the turns and i never hit the rev limiter...
I think one datalog showed 1.4 g's though...must be wrong...As you can here, wheel spin on acceleration is a problem also..that is down to needing tires and LSD..again, $$ https://www.youtube.com/watch?v=hq_bW_IQ63Y |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Ok, here is a video of my fastet run. I just need to go faster! The data logs of my runs show that I was only about .8g's in the turns and i never hit the rev limiter... I think one datalog showed 1.4 g's though...must be wrong...As you can here, wheel spin on acceleration is a problem also..that is down to needing tires and LSD..again, $$ https://www.youtube.com/watch?v=hq_bW_IQ63Y Looking better. I don't follow these courses as well as the more obvious runways. Hard to tell from the vid how bad your tires are. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:40 PM |
