Seabird |
Member ![]() ![]() Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States ![]() |
Hello all!
Having some on going difficulties with my fuel system. Last time at the track I had a lean running condition when under load on the 1-2 bank. Swapped a gasket once back home and now can't replicate the problem. Decided I was going to refresh a few components as a precautionary measure. Fuel regulator (as this is where the split happens between the left and right carbs), fuel pressure gauge (the old one was well old), and adding a spare carb to my track side spares. Previously I had not had a problem with fuel pressure per the gauge. After swapping in a fresh Holley 12-804 and an oil filled gauge I was unable to regulate the pressure down to 3 psi. Was not able to regulated it lower than 15 psi for that matter. A little research on the web indicated that the 12-804 and the higher pressure 12-803 sometimes get mislabeled. So I bought a rebuild kit which came with both springs. Swapped the new low pressure spring into the new regulator. Initially I could get the pressure in the 3 lb range but after a sort while the pressure would creep up. To make matters worse if I bounce the throttle I actually can watch the fuel pressure drop off (IMG:style_emoticons/default/hissyfit.gif) The fuel pump is a Holley blue top so it has a max pressure of 14 psi. My next track day is 2 Saturdays from now so I need to sort this soon. Has anyone else run across this before? Thanks, Miguel |
Seabird |
I was trying to keep it simple for the initial fuel system so I opted for a return-less set up. I have a similar setup on my GTV, but am using a facet pump and redline regulator/filter unit for the components, and it has not given me problems in the last three years.
I have seen a fuel return setup on DCOE's that was simple and clean in theory. A fuel outlet is added to the bowls which lets the bowls over flow back to the fuel tank. The floats are removed and the pick up for this outlet is set at the ideal fuel level line. The bowls always are full and the pressure in the system is minimized. I have the impression that this style of system was outlawed sometime ago.... Either way not trying to reinvent things here. Looking for the simplest system to get me on the track enjoying the ride. M |
Lo-Fi Version | Time is now: 26th June 2024 - 01:36 AM |
