1972 1.7 - Fuel pump not starting when key is turned, Problem with fuel pump |
itsmagic |
Aug 8 2014, 10:46 AM
Newbie Group: Members Posts: 10 Joined: 3-June 05 From: Hyde Park, NY Member No.: 4,193 |
My 1972 1.7 914 recently decided to not start. I quickly noticed that the fuel pump is not running briefly like it should after the ignition key is turned. I verified that the relays on the relay board (Master, Fuel Pump, Blower) are all good by trying them on the headlight motors. I then verified that the two fuses on the relay board are good. Next, I popped the cap on the fuel pump relay and pressed it... the fuel pump runs when I do this. (The car will then start and run for a few seconds if I start it). Sooooo, I am at a loss... The fuel pump is fine, relay board is fine, relays are fine... what could be causing the fuel pump to not activate? Thank you for any advice. Wayne
silverbullet75 |
Aug 8 2014, 11:01 AM
I reject your reality and substitute my own! Group: Members Posts: 18 Joined: 3-December 11 From: Las Vegas, NV Member No.: 13,848 Region Association: Southwest Region |
It's been a while since I've seen this, but depending on your Fuel Injection system, if the flapper is not moving past a certain point, it will not trigger the fuel pump.
I may be off on this though... it's been a couple decades, and I may be thinking about 1.8L. |
itsmagic |
Aug 8 2014, 11:05 AM
Where/what is 'the flapper' ? Thanks.
Lo-Fi Version | Time is now: 30th June 2024 - 10:35 AM |
