1972 1.7 - Fuel pump not starting when key is turned, Problem with fuel pump |
itsmagic |
Aug 8 2014, 10:46 AM
Newbie Group: Members Posts: 10 Joined: 3-June 05 From: Hyde Park, NY Member No.: 4,193 |
My 1972 1.7 914 recently decided to not start. I quickly noticed that the fuel pump is not running briefly like it should after the ignition key is turned. I verified that the relays on the relay board (Master, Fuel Pump, Blower) are all good by trying them on the headlight motors. I then verified that the two fuses on the relay board are good. Next, I popped the cap on the fuel pump relay and pressed it... the fuel pump runs when I do this. (The car will then start and run for a few seconds if I start it). Sooooo, I am at a loss... The fuel pump is fine, relay board is fine, relays are fine... what could be causing the fuel pump to not activate? Thank you for any advice. Wayne
pt_700 |
Aug 8 2014, 12:05 PM
Senior Member Group: Members Posts: 1,095 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
my d-jet was one of those rare computer failures.
shop spent hours checking the basics and finally swapped one from another customer's car and, voila! |
Lo-Fi Version | Time is now: 30th June 2024 - 10:07 AM |
