OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
Next step for me is setting up my valve train geometry. I searched the web and the World and now I have enough information to know that I need more information. I see a few references to an article Jake had on his now extinct forums. The Facebook page is pretty vast. Can someone point me to this article? I think that's my first step toward comming up with more intelegent questions.
FYI: I'm building a 2056 based on a late case. I have Jake's 9550 cam installed I have swivel feet adjusters mounted on 1.7 rockers with solid spacers I am using SS valves and chromoloy push rods I installed 8x10 rocker studs I have used .065" of shim on the cylinders with no head gasket Thanks! (IMG:style_emoticons/default/piratenanner.gif) |
OU8AVW |
One issue I'm having that makes me nervous, my adjusters are almost all the way in leaving very little adjustment to compensate for future valve stretch.
Any advise? I imagine that I could shim the rockers but the instructions say the Raby cams work best without shims? |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,721 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
One issue I'm having that makes me nervous, my adjusters are almost all the way in leaving very little adjustment to compensate for future valve stretch. Any advise? I imagine that I could shim the rockers but the instructions say the Raby cams work best without shims? I ran into the same issue. I am using a 9590 cam I believe its pretty similar to the 9550 you have. I ended up using .030 shims IIRC. I also took a little more off the rockers. The pushrods were a real headache for me and I never did get them cut perfect. So I used pushrods from Smith Bros. they will cut them to whatever length you need and they are right on. http://www.914world.com/bbs2/index.php?sho...=234274&hl= |
Lo-Fi Version | Time is now: 18th March 2025 - 12:38 AM |
