> Valve Train Time, Raby article now posted with permission
OU8AVW
post Jan 30 2014, 06:31 PM
Yacht Rigger
Next step for me is setting up my valve train geometry. I searched the web and the World and now I have enough information to know that I need more information. I see a few references to an article Jake had on his now extinct forums. The Facebook page is pretty vast. Can someone point me to this article? I think that's my first step toward comming up with more intelegent questions.
FYI: I'm building a 2056 based on a late case.
I have Jake's 9550 cam installed
I have swivel feet adjusters mounted on 1.7 rockers with solid spacers
I am using SS valves and chromoloy push rods
I installed 8x10 rocker studs
I have used .065" of shim on the cylinders with no head gasket
Thanks! (IMG:style_emoticons/default/piratenanner.gif)
stugray
post Aug 12 2014, 12:31 PM
QUOTE(OU8AVW @ Aug 12 2014, 10:59 AM) *
What do you think about the lack of adjustment? I did machine the rockers for more clearance but it's still tight.
I was able to get the geometry correct without shims, but it was too close as you see.
I ended up shimming the rockers by ~.040, but my cam was a little more aggressive than yours.
ANd one mistake I made: I did not thread the new studs in far enough the first time and one of my rocker bases was sitting up on the boss of the stud and threw off my measurements.
Make sure the rocker bases are firmly against the head.
OU8AVW   Valve Train Time   Jan 30 2014, 06:31 PM
The Cabinetmaker   Don't know how to find Jake's article, but...   Jan 30 2014, 06:53 PM
Vacca Rabite   Edited for clarity. PM Jake and ask him is its sti...   Jan 30 2014, 07:33 PM
OU8AVW   Awesome Zach. I have PMed jake a time or two on ot...   Jan 30 2014, 08:04 PM
stugray   I just posted the whole article when I noticed his...   Jan 30 2014, 09:31 PM
Jake Raby   I just posted the whole article when I noticed hi...   Jan 30 2014, 10:26 PM
jmalone   Jake, Critics don't matter, they rarely do or ...   Jan 30 2014, 10:43 PM
stugray   Thanks Jake! Posted with permission: Here it ...   Jan 30 2014, 11:17 PM
rick 918-S   Thanks Jake! Posted with permission: Here it...   Jan 31 2014, 10:45 AM
OU8AVW   Thanks guys. If you don't like something in th...   Jan 31 2014, 06:26 AM
Steve Pratel   Thanks guys. If you don't like something in t...   Jan 31 2014, 06:57 AM
OU8AVW   Thanks guys. If you don't like something in ...   Jan 31 2014, 08:11 AM
worn   Thanks guys. If you don't like something in t...   Jan 31 2014, 08:20 AM
OU8AVW   [quote name='OU8AVW' post='1991001' date='Jan 31 ...   Feb 1 2014, 08:18 PM
nathansnathan   Thanks guys. If you don't like something in t...   Jan 31 2014, 08:22 AM
7275914911   Instant Classic OR Saved in the 914Info>Archive...   Jan 31 2014, 07:31 AM
Java2570   Thanks all - this is just what I've been look...   Jan 31 2014, 09:14 AM
Jesco Reient   I used Jakes Valve train geometry article for the ...   Jan 31 2014, 09:34 AM
Chris H.   :agree: Invaluable info.   Jan 31 2014, 11:48 AM
Woody   Nice article Who wrote it? :poke: Se...   Jan 31 2014, 08:27 PM
Jake Raby   Some asshole.   Jan 31 2014, 09:24 PM
Rotary'14   Some asshole. You said it,,,, :poke: :poke:...   Jan 31 2014, 09:41 PM
Charles Freeborn   Some asshole. Reviving this thread. Many tha...   Jul 20 2020, 09:39 PM
djway   [quote name='Jake Raby' post='1991412' date='Jan ...   Jul 22 2020, 03:44 AM
Jake Raby   Sure. Its a lot easier now that we're back t...   Jan 31 2014, 09:50 PM
OU8AVW   Ok, I got started on this process. After reading J...   Aug 12 2014, 09:45 AM
OU8AVW   My cam spec is .426" of lift for all lobes. M...   Aug 12 2014, 09:49 AM
OU8AVW   One issue I'm having that makes me nervous, my...   Aug 12 2014, 10:06 AM
Olympic 1.7   One issue I'm having that makes me nervous, m...   Aug 12 2014, 10:56 AM
Cap'n Krusty   Looking at your last picture, it's pretty evid...   Aug 12 2014, 10:14 AM
OU8AVW   Looking at your last picture, it's pretty evi...   Aug 12 2014, 10:59 AM
Cap'n Krusty   Looking at your last picture, it's pretty ev...   Aug 12 2014, 01:21 PM
stugray   What do you think about the lack of adjustment? I...   Aug 12 2014, 12:31 PM
Jake Raby   After you pick up a pair of rockers off the flo...   Aug 12 2014, 01:48 PM
OU8AVW   When I read shim I think washer. Should I be looki...   Aug 13 2014, 07:50 AM
Java2570   They look like this: Should be able to get t...   Aug 13 2014, 08:01 AM
crash914   I did not realize you are local...I have shims.......   Aug 13 2014, 10:52 AM
OU8AVW   I did not realize you are local...I have shims......   Aug 13 2014, 04:09 PM
OU8AVW   I realized i forgot to post the final numbers on t...   Dec 19 2014, 06:10 PM
stugray   Did you by chance measure the cam lobes before you...   Dec 19 2014, 07:21 PM
OU8AVW   I did not measure the cam, but if you want the spe...   Dec 19 2014, 08:04 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th March 2025 - 03:50 AM
