Cuda911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California ![]() |
What's the point of the little plastic plugs in the trunk bed?
There are three of them under the foam liner. (well actually, I only have two... anyone know where I can find one? I know they are not needed, but I want to make this car as "complete" as possible). Why did Porsche bother designing these holes and then design plugs for them? Drain holes in case I want to use the trunk as a kiddy pool? Also, one is a bit smaller than the other two, and appears to be threaded. Have a plug you can spare? Thanks! . Attached image(s) ![]() |
Cuda911 |
So with the threaded one, the idea is that I can choose whether I want the spare in the front or the rear?
Back to the other two holes/plugs: Anyone else know? Pete, an interesting guess, but it can't possibly be correct. First of all, the plugs are meant to be left in place. By your theory, I would need to remove them to easily close the trunk. Second of all, they are below the foam pad and the carpet, which would block air flow through them. |
Lo-Fi Version | Time is now: 28th June 2024 - 07:32 PM |
