> Battery Connection Help
AvalonFal
post Aug 19 2014, 03:21 PM
I've been having problems with the battery draining over a couple of days of non-use, so I'm intending to replace the PO's battery cables (a few splices in the current ones) and go from there. PO relocated battery to the rear trunk & that's OK. However, I came across this situation:
- Engine off, key out.
- (+) battery cable disconnected at battery
- (-) battery cable still connected
I measured across the disconnected (+) cable to the connected (-) cable & got a voltage of around .6 - .75 volts. Is this normal to have voltage across a disconnected (+) cable??
Car starts fine when battery is charged, but, as I said, battery loses juice after being idle for a couple of days.
AvalonFal
post Aug 20 2014, 06:32 AM
Yes, there is an aftermarket stereo in car. Meter on DC and hooked up correctly. Car has had most rust removed/neutralized.
I cleaned and tightened up a lot of the easily accessible electrical connections and now the voltage reading is down from .7V to about .25V.
Paul
- Lo-Fi Version Time is now: 27th December 2024 - 03:20 AM
