R8CERX |
2014 New year resolution: To get along with Woody... ![]() ![]() ![]() Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California ![]() |
Hello Folks!
So, need more meat all around the car--2.7RS engine is way too much power to put down on the existing 205/50-15. I am certain many of you have come to this point--need your advise in order to not reinvent the wheel (punt intended!) (IMG:style_emoticons/default/biggrin.gif) Conditions: 1-want to keep existing 914-4 suspension, links, and brakes (actually, front brakes are fitted with BMW calipers; rears are still stock). 2-Planning to add spacers to the wheels in order to gain more space inside fenders (thus need to flare front and rear fenders; for certain rear fenders) 3-Want to keep same size tire all around; so I can rotate them. OPEN FOR CHANGES: A-Open to changing springs and shocks--please advise brand and rate of springs/suggestions B-What size rims/brand or from what car (944 for example) could I get rims to fit 235? 225? what has worked for you? or I should avoid? C- Can the existing 4 bolt pattern hubs be converted into a 5 lug pattern hub? D- will add spacers to either 4 or 5 pattern as needed and add screw/bolt INSERTS E-Should I keep the 4 bolt pattern over the 5 bolt pattern? cheaper rims in 4 configuration? (IMG:style_emoticons/default/confused24.gif) PS- I will be selling rims and tires once I get the above set up going; anyone has parts to exchange for what I trying to do, I am all ears! (IMG:style_emoticons/default/blink.gif) Look forward to your inputs! Regards R8CER X (IMG:style_emoticons/default/first.gif) Attached image(s) ![]() |
ned911 |
Member ![]() ![]() Group: Members Posts: 54 Joined: 11-September 12 From: Austin, TX Member No.: 14,912 Region Association: Southwest Region ![]() |
What tires are your running? Auto-x DOT rubber?
My first thought is the Fuchs are too narrow for 205/50x15's. Can you borrow someone's 15x6's or 15x7's (I'm not sure 15x7 will fit under stock fenders). Most 944's run 15x7's either cookie cutters or phone dials. I use the 15x7 cookies on my 911 for race tires with 225/50x15 Kuhmo's but that takes some fender massaging to not have any rub. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:15 PM |
