R8CERX |
2014 New year resolution: To get along with Woody... ![]() ![]() ![]() Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California ![]() |
Hello Folks!
So, need more meat all around the car--2.7RS engine is way too much power to put down on the existing 205/50-15. I am certain many of you have come to this point--need your advise in order to not reinvent the wheel (punt intended!) (IMG:style_emoticons/default/biggrin.gif) Conditions: 1-want to keep existing 914-4 suspension, links, and brakes (actually, front brakes are fitted with BMW calipers; rears are still stock). 2-Planning to add spacers to the wheels in order to gain more space inside fenders (thus need to flare front and rear fenders; for certain rear fenders) 3-Want to keep same size tire all around; so I can rotate them. OPEN FOR CHANGES: A-Open to changing springs and shocks--please advise brand and rate of springs/suggestions B-What size rims/brand or from what car (944 for example) could I get rims to fit 235? 225? what has worked for you? or I should avoid? C- Can the existing 4 bolt pattern hubs be converted into a 5 lug pattern hub? D- will add spacers to either 4 or 5 pattern as needed and add screw/bolt INSERTS E-Should I keep the 4 bolt pattern over the 5 bolt pattern? cheaper rims in 4 configuration? (IMG:style_emoticons/default/confused24.gif) PS- I will be selling rims and tires once I get the above set up going; anyone has parts to exchange for what I trying to do, I am all ears! (IMG:style_emoticons/default/blink.gif) Look forward to your inputs! Regards R8CER X (IMG:style_emoticons/default/first.gif) Attached image(s) ![]() |
R8CERX |
I am using currently 205/50-15 Hoosiers--they did rub inside the fender, so it is correct about them rubbing!!
I currently have HOOSIERS SM7 (spec miata) 40 DOT tread wear racing tires I do have a set of 5 lug cookie cutters that have a stamp 7Jx15H2 -how wide of a rubber can I put on these babies? can I go to 225? or greater? They were for my original 914-6 that used to use when I raced that baby. if so, all I need to do is put the wheel spacers, change the 4 lug to 5 lug patter on the hubs and weld the new 5 screw/rods to the hubs? (plus flare rear fenders; front may not be needed to flare?) anyone can confirm on my assumption above? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:26 PM |
