Battery Connection Help |
AvalonFal |
Aug 19 2014, 03:21 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
I've been having problems with the battery draining over a couple of days of non-use, so I'm intending to replace the PO's battery cables (a few splices in the current ones) and go from there. PO relocated battery to the rear trunk & that's OK. However, I came across this situation:
- Engine off, key out. - (+) battery cable disconnected at battery - (-) battery cable still connected I measured across the disconnected (+) cable to the connected (-) cable & got a voltage of around .6 - .75 volts. Is this normal to have voltage across a disconnected (+) cable?? Car starts fine when battery is charged, but, as I said, battery loses juice after being idle for a couple of days. |
AvalonFal |
Aug 22 2014, 02:21 PM
After pulling fuses, relays, pins, cables and cutting spliced wires, I think I've narrowed down my current draw to 1 of the 2 larger (4mm2) unfused red wires that run from the battery up the tunnel - 1 to ignition switch & the other to the fuse panel. When I cut these 2 wires (they were already spliced because the battery was moved to the rear trunk & the wiring had to be made longer to reach it), all current draw stopped.
Now I just don't know which one of the 2 wires it is - ignition sw. or fuse panel. Anyone know of an "easy" way to find out?? Also, where exactly does the 1 red wire end at the fuse panel? Thanks in advance. Paul |
Lo-Fi Version | Time is now: 27th September 2024 - 08:16 AM |
