02loftsmoor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region ![]() ![]() |
I'm following a guideline that Ray posted a while back on using 1.7 heads, opening up the exhaust valve to a 1.8 exhaust valve..and the port the hell out of the exhaust port. relocate the spark plug.
I need some guidance , pictures, measurements anything that could help me DYI port these heads. and I will say please and thank you, and will buy a beverage of your choice. (IMG:style_emoticons/default/beerchug.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Here's a tip: Don't touch the short radius of the exhaust port. Taking material off there doesn't help flow much if at all, and it takes material out of a part of the head that is a bit marginal in strength already.
--DD |
02loftsmoor |
Here's a tip: Don't touch the short radius of the exhaust port. Taking material off there doesn't help flow much if at all, and it takes material out of a part of the head that is a bit marginal in strength already. --DD --DD could up help out this knowledge challenged person right where in int port that is please.. Wes |
Lo-Fi Version | Time is now: 25th June 2024 - 10:19 PM |
