AvalonFal |
Member ![]() ![]() Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region ![]() |
I've been having problems with the battery draining over a couple of days of non-use, so I'm intending to replace the PO's battery cables (a few splices in the current ones) and go from there. PO relocated battery to the rear trunk & that's OK. However, I came across this situation:
- Engine off, key out. - (+) battery cable disconnected at battery - (-) battery cable still connected I measured across the disconnected (+) cable to the connected (-) cable & got a voltage of around .6 - .75 volts. Is this normal to have voltage across a disconnected (+) cable?? Car starts fine when battery is charged, but, as I said, battery loses juice after being idle for a couple of days. |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
There is a very much easier way to make a shunt.
Use a 6" piece of #12 copper ground wire from a piece of old house wiring. Hook it to two thin bolts and connect a couple of 12" 12 gage wires to the bolts. Put alligator clips on the other ends. Now hook up a known current draw in series with the "shunt you just made. Hook the source to the battery in-line with the shunt. Measure the voltage drop across the shunt only at the two bolts. this is the voltage drop across that shunt for a known current draw. Now hook your shunt in-line with any other current draw and use a formula to figure out the current draw. New voltage drop divided by the known voltage drop, times the known current draw, = the new current draw. Tom |
Lo-Fi Version | Time is now: 25th June 2024 - 11:14 PM |
