> Battery Connection Help
AvalonFal
post Aug 19 2014, 03:21 PM
I've been having problems with the battery draining over a couple of days of non-use, so I'm intending to replace the PO's battery cables (a few splices in the current ones) and go from there. PO relocated battery to the rear trunk & that's OK. However, I came across this situation:
- Engine off, key out.
- (+) battery cable disconnected at battery
- (-) battery cable still connected
I measured across the disconnected (+) cable to the connected (-) cable & got a voltage of around .6 - .75 volts. Is this normal to have voltage across a disconnected (+) cable??
Car starts fine when battery is charged, but, as I said, battery loses juice after being idle for a couple of days.
stugray
post Aug 23 2014, 04:39 PM
SO the draw is downstream of the the connection at the fuse panel.
Take each fuse out and see when the drain disappears.
If you take them all out and the drain persists, then the panel is the problem.
- Lo-Fi Version Time is now: 27th December 2024 - 02:56 AM
