rmdinmd |
Member ![]() ![]() Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
found out why my oil temps have been so high. I discovered the other week that the alternator bolt went through the fan, (IMG:style_emoticons/default/sad.gif) I knew it had taken out two blades but discovered today it took out six!! (IMG:style_emoticons/default/sheeplove.gif) I am (was) planning on going to okteenerfest and am hoping to get this fixed quickly.
My question is can I replace the fan with the engine in or will I need to drop the engine in order to replace. I have a replacement that is missing only one blade and am hoping that will get me by. TIA Rick |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I have replaced the fan in the car, but you have to pull the front engine tin and go downward to get enough clearance.
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
I have replaced the fan in the car, but you have to pull the front engine tin and go downward to get enough clearance. Ditto. Done the same on two occasions. Not the PITA you might think. You will need a small diameter bar to apply leverage when adjusting alt belt tension. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:43 AM |
