lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
Bought a set of top targa window seals (left / right).
I'm having a heck of a time trying to figure out how to install them. I tried from the bottom up, top down, one side in all the way, push the other side into the rail (this works best, but mucks up the rubber you're pushing on).... Tried lube all around the rail and rubbers, etc. It just isn't happening for me, so I'm wondering if there is some trick that I don't know about? Any input would be helpful - before I totally screw it up. Thanks, Len |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Bought a set of top targa window seals (left / right). I'm having a heck of a time trying to figure out how to install them. I tried from the bottom up, top down, one side in all the way, push the other side into the rail (this works best, but mucks up the rubber you're pushing on).... Tried lube all around the rail and rubbers, etc. It just isn't happening for me, so I'm wondering if there is some trick that I don't know about? Any input would be helpful - before I totally screw it up. Thanks, Len Liquid soap to lube them and a pair of pliers on the end to pull them in. Pulling stretches them pushing expands them. Had the same problem. It it it the seal on the back edge of the window there are a couple on dents that need to be flattened to get them to slide in. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:22 AM |
