> Your current TYPE IV set up, Tell me what you have and what you think about it
Hine62
post Aug 25 2014, 10:38 AM
I'd like to know what some of the members are running for a type iv. Please answer the following questions:
1. What is the stroke, bore, and CC's of the engine?
2. If the engine is stroked over 71mm what case work was needed?
3. What cam are you running?
4. If using carbs/EFI, what is the setup?
5. What's the HP, or do you feel the engine has good torque/HP for the setup you have?
6. Comments on anything else...
Hine62
Hine62
post Aug 25 2014, 03:34 PM
Great info! I'd post mine but it's stock 1.8 with dual 34s and it needs more power...
Anyone else want to post their setup?
Hine62
Hine62   Your current TYPE IV set up   Aug 25 2014, 10:38 AM
crash914   103 bore, 80mm stroke, reduced base circle cam, re...   Aug 25 2014, 10:53 AM
Mark Henry   I have about the same engine as Herb in my '6...   Aug 25 2014, 10:58 AM
colingreene   mines a 94mmx78mm makes it a 2258 we did clear the...   Aug 25 2014, 12:04 PM
malcolm2   I'd like to know what some of the members are...   Aug 25 2014, 12:52 PM
Hine62   Great info! I'd post mine but it's sto...   Aug 25 2014, 03:34 PM
Elliot Cannon   FAT Perfromance built. 76 crank, 96 pistons, 44id...   Aug 25 2014, 04:00 PM
Kansas 914   I didn't build the motor - but it is in my car...   Aug 25 2014, 04:05 PM
WLD419   My new rebuild I just finished,(still putting toge...   Aug 25 2014, 06:44 PM
saigon71   My new rebuild I just finished,(still putting tog...   Aug 25 2014, 06:58 PM
WLD419   [quote name='WLD419' post='2078162' date='Aug 25 ...   Aug 25 2014, 08:07 PM
saigon71   I'm running a stock 2.0 D-jet. 95HP, 94 x 71 ...   Aug 25 2014, 07:08 PM
mepstein   Stock '71 - 1.7 in a stock car. Minimal horsep...   Aug 25 2014, 08:25 PM
Porschef   2056 w AA cylinders and KB pistons. 9550 cam, Ljet...   Aug 26 2014, 06:46 AM
malcolm2   2056 w AA cylinders and KB pistons. 9550 cam, Lje...   Aug 26 2014, 02:45 PM
Bleyseng   2056 w AA cylinders and KB pistons. 9550 cam, Lj...   Aug 27 2014, 05:43 AM
Bleyseng   2056cc with 96mm pistons 71mm stroke, 9 to 1 CR, 4...   Aug 26 2014, 07:22 AM
eyesright   Home rebuild of a stock '76, FI 2L. My crank...   Aug 26 2014, 10:18 AM
malcolm2   2056cc with 96mm pistons 71mm stroke, 9 to 1 CR, ...   Aug 26 2014, 02:50 PM
Dtjaden   2056 cc European Motorworks 96mm pistons & bar...   Aug 26 2014, 10:29 AM
Johny Blackstain   My LE has it's original 2.0 engine using stock...   Aug 26 2014, 11:29 AM
Hine62   Lots of great information. It looks like the 2056 ...   Aug 26 2014, 02:22 PM
Dtjaden   Lots of great information. It looks like the 2056...   Aug 27 2014, 08:57 AM
Porschef   Malcolm, I'll be damned if'n I can't c...   Aug 26 2014, 02:57 PM
malcolm2   Malcolm, I'll be damned if'n I can't ...   Aug 26 2014, 03:06 PM
Porschef   Yuppers on the MPG's. They're better with ...   Aug 26 2014, 03:19 PM
Jake Raby   Its all in the combo.   Aug 27 2014, 08:43 AM
Dion   Hello, "2056" 76 case,stock crank, ...   Aug 27 2014, 11:04 AM
Vacca Rabite   2056. Raby 9350 carb cam. german cylinders machi...   Aug 27 2014, 06:20 PM
- Lo-Fi Version Time is now: 26th December 2024 - 07:37 PM
