> car is bucking under acceleration...any ideas?
era vulgaris
post Aug 27 2014, 02:04 PM
J is for Genius
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first?
Mike Bellis
post Aug 27 2014, 02:50 PM
Resident Electrician
sounds like a lack of fuel.
era vulgaris   car is bucking under acceleration...any ideas?   Aug 27 2014, 02:04 PM
Mike Bellis   sounds like a lack of fuel.   Aug 27 2014, 02:50 PM
jt914-6   When you get the bucking worked out check your mot...   Aug 27 2014, 03:23 PM
Rand   Don 't know if the TPS would cause bucking to ...   Aug 27 2014, 03:45 PM
wndsnd   Car still have the Djet? Has the tank ever been c...   Aug 27 2014, 03:45 PM
era vulgaris   Motor mounts and trans mounts are still good. TPS...   Aug 27 2014, 04:32 PM
brp986s   Motor mounts and trans mounts are still good. TP...   Aug 27 2014, 07:31 PM
era vulgaris   Any chance a dying fuel pump would cause this? Ju...   Aug 27 2014, 04:52 PM
Mike Bellis   Any chance a dying fuel pump would cause this? J...   Aug 27 2014, 06:52 PM
scotty b   Check all of the vaccum lines. there is one in par...   Aug 27 2014, 07:18 PM
jasons   When my 2.0 did this, it was the trigger points in...   Aug 27 2014, 07:21 PM
mepstein   Mine did this. Did a LOT of things to try to fix b...   Aug 27 2014, 07:52 PM
warrenoliver   Could be a loose ground wire on your distributor p...   Aug 27 2014, 09:16 PM
era vulgaris   Check all of the vaccum lines. there is one in pa...   Aug 27 2014, 09:44 PM
BeatNavy   I think it's probably worth reading this thre...   Aug 28 2014, 04:30 AM
76-914   What's your fuel pressure?   Aug 27 2014, 09:46 PM
The Cabinetmaker   I'm surprised that no one has mentioned the f...   Aug 28 2014, 04:03 AM
dknechtly   There's a lot of good advice here. Make sure ...   Aug 28 2014, 07:55 AM
era vulgaris   So first I cleaned every contact I could find in b...   Aug 28 2014, 01:29 PM
Phoenix914   :headbanger: :Qarl: :driving:   Aug 28 2014, 03:43 PM
The Cabinetmaker   don't you love the simple fixes   Aug 28 2014, 04:19 PM
era vulgaris   Definitely! :Qarl:   Aug 28 2014, 04:40 PM
era vulgaris   Celebrated too soon :( Went for another drive t...   Aug 28 2014, 09:44 PM
PancakePorsche   Celebrated too soon :( Went for another drive ...   Aug 29 2014, 02:33 AM
era vulgaris   Got a friend bringing over his fuel pressure gauge...   Sep 2 2014, 05:35 PM
Rand   Disregard that since you have a carb now. You don...   Sep 2 2014, 06:20 PM
era vulgaris   Disregard that since you have a carb now. You do...   Sep 2 2014, 07:12 PM
r_towle   I would suggest a few things. A new fuel tank sock...   Sep 2 2014, 09:47 PM
era vulgaris   I would suggest a few things. A new fuel tank soc...   Sep 3 2014, 09:05 AM
BeatNavy   Is there a good guide somewhere to pulling and c...   Sep 3 2014, 09:22 AM
era vulgaris   I say again (from page 1 of this thread), you may...   Sep 3 2014, 10:49 AM
BeatNavy   [quote name='BeatNavy' post='2081511' date='Sep 3...   Sep 3 2014, 01:24 PM
914_teener   I would suggest a few things. A new fuel tank soc...   Sep 2 2014, 10:22 PM
era vulgaris   Couple of extra things I thought of: Check your...   Sep 3 2014, 09:08 AM
914_teener   :agree: I assumed you had already done this. Ge...   Sep 3 2014, 09:47 AM
BeatNavy   Sorry, a couple more things to note: you probably...   Sep 3 2014, 02:08 PM
era vulgaris   Sorry, a couple more things to note: you probabl...   Sep 3 2014, 04:05 PM
BeatNavy   Sorry, a couple more things to note: you probab...   Sep 3 2014, 04:18 PM
jacksun   hi, maybe the below will help? "Throttle Swi...   Sep 3 2014, 07:52 PM
era vulgaris   Aha! i finally got it. After a couple weeks ...   Sep 15 2014, 11:47 AM
BeatNavy   check the obvious shit first before diving into t...   Sep 15 2014, 11:56 AM
era vulgaris   But at least you learned a lot of things that co...   Sep 15 2014, 01:10 PM
dknechtly   Geesh, thanks for posting the solution. That...   Sep 15 2014, 12:16 PM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 02:20 AM
