Pedrini 00 wheels need to fit a later hub, Ways to cut the opening to fit the centering ring??? |
bandjoey |
Aug 29 2014, 03:38 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I have to replace a bent wheel and picked up a good replacement from BD Stone.
(Thanks!) I am going to have the 00 Pedrini early wheel cut to fit the later hubs with centering rings. So far in the DFW area I've only found a couple of shops that say they can do this at $125 per wheel. Wheeeeho! (IMG:style_emoticons/default/dry.gif) That's a little steep for me! Outside of this, I think my other option is to bolt the wheel to a spare hub, mark the distance to cut out, and dremel tool the opening to a close fit. I know it will still be a lug centric wheel, since I can't cut it exactly to fit and centered. i think it should balance ok. Mayo's Performance here can lug centric balance wheels. Any suggestions doing this or is there a better way? Anyone done this at home? All suggestions welcome. I've searched many ways and can't find a thread on the actual cutting. Thanks (IMG:style_emoticons/default/flag.gif) Bill |
bandjoey |
Aug 29 2014, 03:56 PM
Mike did u use a machine shop or wheel shop? I've been calling just wheel shops. Thanks
Mblizzard |
Aug 29 2014, 04:06 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Mike did u use a machine shop or wheel shop? I've been calling just wheel shops. Thanks Machine shops only. Get the tires dismounted and take it to a machine shop. I had my cut 80 mm in diameter and 13 mm deep. Seems to work well you can measure your hubs as I think 79mm would work also. |
Lo-Fi Version | Time is now: 27th December 2024 - 07:48 AM |
