Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
My AFR gauge arrived yesterday and I was all amped to install it today. A few weeks back when I installed the sway bars I welded in a bung for the O2 sensor in the stock Leistritz muffler in anticipation of this day, however, it appears I may haven't enough room to install the sensor without cutting sheet metal.
Ain't gonna do that. The kit includes a bung so I'll just abandon the prior unit with it's plug, and weld in the new one (Oh Paul, where art thou ;-) Question is, where? I know it's gotta be between the 9:00 and 3:00 positions, but would it behoove me to place it near the exhaust tip, or is anywhere else ok? Anyone face this dilemma? (IMG:style_emoticons/default/blink.gif) Thanks, Joe |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
If it is a heated wide band, it can go near the tip. If it is a non heated narrow band, it need to go closer to the heat source.
tomrev |
Member ![]() ![]() Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None ![]() |
If it is a heated wide band, it can go near the tip. If it is a non heated narrow band, it need to go closer to the heat source. I think for a meaningful measurement, it needs to be closer to the ports. Ideally in the collector for the bank. The muffler, or muffler tip will have too much oxygen not related to combustion, and give you a very inaccurate #. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:08 AM |
