Oil leak woes |
Oil leak woes |
Mikesavina |
Aug 30 2014, 11:50 PM
Newbie Group: Members Posts: 26 Joined: 15-September 12 From: Clarksburg WV Member No.: 14,936 Region Association: MidAtlantic Region |
Need some help tracking down my oil leak. I have oil all over the passenger side tin on the top, doesn't appear to be coming from breathers or oil fill tank, it's a complete mess with oil even on the firewall. I have ran it after cleaning and can't track down any leak, however after driving a short distance the tin is covered with oil even tracing the rear glass. So where in the heck could it be coming from? Oil cooler doesn't seem to be wet. Any help would be great
Mikesavina |
Aug 31 2014, 09:54 AM
Sorry, it's a 75 2.0 with dual carbs, the oil doesn't appear to be coming from the front Of the engine, it tends to pool at the rear of the tin, may just be that the tin has a low spot but it is coincidentally near the breather on the head. Hoses on the breather are not cracked however I did smell rubber burning while driving. The Hoses are heater hoses if that makes any difference. Also noticed there is no PCV it just recirculates into the filler neck. Thanks
Mikesavina |
Aug 31 2014, 09:58 AM
Sorry, it's a 75 2.0 with dual carbs, the oil doesn't appetite to be coming from the front I the engine, it tends to pool at the rear of the tin, may just be that the ton has a low spot but it is coincidentally near the breather on the head. Hoses on the breather are not cracked however I did smell rubber burning while driving. The Hosea are vacuum if that makes any difference. Also noticed there is no PVC it just recirculates into the filler neck. Thanks My apoligies for the spelling errors, my autocorrect is a little crazy today Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 10:59 AM |
